Bedlam
Aug 12, 2014Moderator
Selecting the Arctic Fox with dual 30 lb LPG cylinders over the others with only 20's was a factor. I knew the Onan would suck down LPG faster than even the equivalent gasoline model, but I did not want the hassle of setup, storage and security of an external model. I also can carry an additional 100 lbs of LPG in my trailer if I know we will have a lot of generator use or be running our LPG campfire.
Roadlover: How about a little background on when and for what do you use your generator? Perhaps if we know why you need electricity and how much, we can give you some suggestions that would benefit you instead of opinions based on our usage.
44,066 PostsLatest Activity: Jul 25, 2018
