Acdii
Oct 12, 2016Explorer
Bumper mod
I want to be able to mount my Champion generator on the rear bumper, which means replacing it. So would 3/16" square tube with 3/16" plates, angles, etc. welded to the frame be strong enough? I am thinking that I can build the new bumper with fresh steel, cut off the old one, and slide the attachments between the I beams of the frame and bolt it on. I want to extend the bumper out about a foot too, so will need to cantilever it out, bringing the attachment forward about 2 feet in. I would use at least 5 1/2" grade 8 bolts on each side to secure it, instead of welding to the frame, but the bumper itself will be welded with angles and gussets.
I believe 3/16" for the bumper itself should be plenty strong, but the attachment part is where I wonder if I should go heavier gauge. I plan to make it so that it slides over both sides of the frame, and is boxed top and bottom with gusset plates that cover the entire top and bottom of the tube, with angles on either side.
I have a nice plasma cutter and welder that I have been wanting to put to use other than the light tacking I have done for repairs. Gives me a reason to buy a tank of gas too. :)
