- Motard112ExplorerHere is a pic.last summer water was in between the linoleum or contact paper and the wood so I cut that strip out to let the water dry out .but the greenish white(linoleum a contact paper material) covering the plywood is what I'm looking for to replace since I had to cut a strip out.it is not aftermarket .both sides are the same .the camper is a 2010 palomino s17.hopefully the pic clears up any questions
- Motard112ExplorerNo its like a contact paper material .give me a minute and I will post a pic
- T3rry1Exploreryeah mine's just plain plywood under the mattress pads, it must be an aftermarket job.
- bikendanExplorerare you talking about the inside surface of the bunk end door?
i know of no hybrid that has linoleum in the bunk door, unless a previous owner did some mod.
it always helps if you tell us what year/model of hybrid you're talking about.
44,066 PostsLatest Activity: Apr 15, 2026
