Where to start?
1. That "Duratain" is a big waste of money. They merely spray (if they even do that)some Scotchguard on the woven fabrics and a spray wax on the outside. They probably have about $100 in the whole process. They make more money on those add ons than on the whole deal.
2. The electric brake controller is a must, but worth about $200 at the very most.
3. You will be pushing your Toyota to the very max with actual weights, but the dynamic forces of that trailer will be pushing that van around big time. You will not enjoy the towing experience and probably not use the RV because of it.
4. I am offended by the "if you buy tomorrow will add in the hitch." That is just putting undue pressure on you to buy and shows zero respect for you. Do you really think day after tomorrow they would not do the same deal?
5. A very quick Google search found that very same trailer for $2000 less.
6. DO NOT pay anything extra for a pre-delivery inspection.
7. Do not buy an extended warranty...another rip off.
8. You should be looking for a much smaller trailer or better yet a pop up. Your van will tow it much better and safer.
9. Consider buying used. Most RVs are used a few times and then are sold. If you buy that big a trailer to tow behind your van, that is what will happen to you. You will tow it two or three times, realize it is mistake, and sell your trailer.
10. RVs depreciate faster than a rock sinks in water. Again, buy used.
11. You need to do much more research before you buy. This forum has a wealth of information. Study the many different RVs. Study the many different brake controllers. Study the many different hitches. You are no near ready to make an informed decision in buying.
12. A RV show is a great place to start, but leave your check book at home. There will be relentless pressure to buy.
