BoilerEE's avatar
BoilerEE
Buying EC1160 - having weight anxiety ...
I know, I know, not another "I'm intentionally overloading my truck - tell me it's OK!" thread, but yeah, that's where I'm going ... sorry!
OK, that being said, I'm getting ready to pull the trigger on an '07 Eagle Cap 1160, and I was all ready to accept that it was going to be heavy, but then I read Boatycall's weight thread saying his 1160 weighs like 7500# (!) Now, I know his rig is a bit different (batteries made of neutron star or something), and a newer model of 1160, but if this '07 is anywhere near that heavy even I'm going to be well past my comfort limit.
So, my rig is an '07.5 3500HD, D-max, dually, stock other than RS9000's, Firestone 'bags, and I just ordered the StabilLoads to add as well. Have TL tiedowns on it.
The GVWR of the truck is only 11,300, which I've exceeded in the past with minimal problems - I've been up and down the AlCan multiple times with the setup you seen in my sig which was just shy of 25k# GCVW. Before my previous adventures in overloading, I decided my personal limit was to stay under the wheel limit, which Accuride says is 2440/ea, so no more than 9760 on the rear, which is over GM's GRAWR of 8,200 but under the AAM1150's design load and under the tire limit (even though it's got the silly looking tiny 215/85/16s).
So I guess what I'm saying is, does anyone have experience with the same(ish) setup (like pre-'11 GM dually) or, ideally, a weight ticket for an older EC1160? Again, I was all ready to jump on this thing, but that "my EC1160 weighs 7500#s" is keeping me up at night.
BTW, the reason I don't just go try it out and drive over a scale before buying is that there aren't any big TC's up here in Alaska that I can find, so I'm doing this all long-distance down in Seattle and will probably have to make a decision with only my brother having put eyes-on it.
Thanks!
  • Thanks wnjj! That was enough to push me into it - deal is done! :-)
    Got a monster deal on it - $20k! Now for another blast up and down the 'ol AlCan to pick 'er up ... that is unless one of you wants to grab it and drop it up here for us!
  • It's been my opinion that small is better/ beautiful as long as it Is enough.
    Keeping it simple/ lighter is better IMHO.
  • Wow! over 7K camper on his dually truck with 6.0 gas engine and gets 9-10 mpg.
    Probably uphill into a wind. I have had two buddies with North Star pup up campers srw short box trucks same engine and would love to have gotten that kind of mileage. No knock on the engine very dependable etc..
    Sorry a little off point there, shame on me.
    Beautiful camper you are buying!! Sounds like you are taking the necessary steps to make the truck work with the camper.
  • wnjj's avatar
    wnjj
    Explorer II
    I found this quote from the Eagle Cap Owners forum:
    "I have a 1160 that I have carried on both my 03 Duramax and now I have it on a 2012 6.0. Both trucks are stock and 3500 DRW. I didn't have any problem with either truck except the 03 was over the max gvw by about 800 lbs. It handles fine on the 2012 without any modifications, I get between 9 and 10 Mpg loaded, real nice truck."
    800 lbs over on an '03 doesn't seem too bad. I don't know why Boatycall has lead-lined walls in his.
