temccarthy1
Nov 30, 2015Explorer
Have you seen and toured the TT in person yet? Certainly do not buy it now if you haven't looked it over with a fine tooth comb by visiting the dealer...It should have a full warranty in case you discover a problem in the Spring. Check out your local RV dealer to make sure they will perform warranty work on this one even if they don't sell that brand. Don't you have time to go check it out and buy it and bring it back now if it meets your requirements? The dead of winter with the bad storms and such is still 30 days away in Jan and Feb. And you need to see in person and have in writing that it WAS winterized.. You can tell very quickly by checking the faucets for pink AF as well as the toilet bowl. Not to mention, IMO if you buy now, buy a good TT cover and protect it at your house from the ice, snow and sleet.. The dealer certainly won't cover it! Why let him sit on it uncovered and exposed if you are definitely going to buy it? Good luck!
