tshirtman
Dec 03, 2015Explorer
UPDATE---
Still in negotiations but the last offer from the dealer was "AS IS"
being it is a 2013 it is out of warranty and Jayco will most likely do nothing if it does not work. The dealer said they do a:
Pressure test on the water lines for leaks ,gas line for leaks and turn on all appliances and make sure they work.
Yes I will go there and get it asap as all of your advice makes perfect sense. Would it make sense to hire a independent tech in Idaho to do an inspection for me to see if there are any MAJOR ISSUES? I have 2 very good mobile RV techs here in my area that can do all of the stuff here but want to not get snake bit from afar.
thank you all for your support:)
