silverbullet555
Jun 28, 2020Explorer
jaycocreek wrote:
All you have to do is check your batteries more often and add water when necessary if you think the Magnate is your issue..Some of the older chargers don't have a shut off so a guy just has to maintain the batteries more often and you won't fry your battery..My TC is older than yours and it isn't frying my batteries but I do check them regularly and I am plugged in 24/7....
Owning an older TC or pickup and reading these forums where the majority of truck campers and trucks are much newer,you have to take things with a grain of salt sometimes or you will put more money into either than there worth...I always go by..if it ain't broke don't fix it...
My vote is to just check your battery more often and you will be fine unless there is something else wrong with your charger...I have owned a bunch of old truck campers and trailers and never have had to replace the inverter charger in any of them and some were real hummers...lol
Fair points. I bought a regular deep cycle battery so I could add water if need be.
