NRALIFR
Jun 29, 2020Explorer
silverbullet555 wrote:
........ Did you replace with the one that goes right into that spot or take another route? I certainly like the potential of an easy swap with no fab required. Is it worth the extra money? Don't know.......
Yes, I replaced mine with the PD 4645. I needed the replacement to fit in that space, as I don’t have another spot that lends itself as well as that one does.
That was about 10 years ago I’d say, and if I were to need to do it today, I’d probably choose the PD 4645VL for the lithium battery support. It’s selectable with a jumper, so you can use it with a non-lithium as well. I think it’s worked out quite well. I don’t have the Charge Wizard pendant, I just open the front cover and use the button on the new fuse board. The charge wizard is built into the board, the pendant is just a remote button.
