lawrosa
Sep 18, 2016Explorer
C5H RPO code 6900 lb GVWR and WD issues
Hey since my door tag vin decal is missing I read that my RPO code C5H list my truck @ 6900 lbs GVWR.
Normally trucks I see my year and style have variable GVWR with an ext cab long box 2006 silverado. Specs commonly show 6400-6700.
Axle weights show on the other trucks I been looking at 3925 front axl rate and 3750 rear axl weight.
Would I assume different #'s for my axles with this new found info on my RPO code C5H? It seems it gives it 200 lbs or so more GVWR .
I cant for the life of me find any info on this.
Can it be part of the Z85 trailer suspension pakage I have?
Also Im going to get new shocks for the truck and was looking at the bilsteins. The Z85 package shows the truck came with 36mm mono tubes. Are the bilsteins compatable?
Im doing this as im not sure why im getting porpoising while towing this light trailer.
I use WD but the TW on the trailer is only 500 lbs or so. This worked good for my s10 but the silverado rocks like a see saw if I hit certain bumps. Can it bee the 157" wheel base?
Can it be that no WD is needed and the 1000 lb WD bars are acting as a spring?
