jshupe wrote:
austingta wrote:
jshupe wrote:
The major limiting factor for a stock 2500HD is the rear tire capacity. If you have 20s, even more so. 6200# RAWR or you'll be over.
FAWR is 5200
RAWR is 6200
tires are 1450 pounds max @ 75PSI each.
Thanks
1450? At 1450, you'd be overloaded with an empty truck (mine had around 3200# empty RAW). If you have 18s, they may be around 3450#. Is that what you meant?
On the 2500HD, the RAWR is derated to 2x 20" rim capacity. Axles and brakes are the same part numbers as 3500HD SRW. Only difference is an upper overload that engages around 6k# RAW on the 3500HD; doesn't exist on the 2500HD. If you have 18s on your 2500HD, you have the same config that the 3500HDs come with - they don't offer 20s. So the only thing you are missing is the overload.
That was kgs. Correction: 3190 pounds each.
