Acdii's avatar
Acdii
Calculating TW from scale readings?
I weighed my rig today after picking up the trailer. What I didn't do was weigh it before hand. I did fill the gas tank up first. My front axle is 3000#, rear 3400#, and trailer 4480#, or roughly there, total weight 11120#. This is with a dry trailer, and nothing in the truck except me. Once I weigh my empty truck without the trailer, what do I need to do to calculate the trailer TW? The specs say it has 630# TW when dry.
  • LarryJM wrote:
    Simple. Weigh the truck with the tongue and without the tongue and subtract the difference.
    Correct with the provision that if you have a WDH system make sure the WDH bars are not connected when you weigh with the trailer hooked up to the truck.
    Larry
    And an extra/extra provision of subtracting any weight that came off the front axle when hooked up. If front axle weight changes by 300# from unhooked to hooked, subtract that 300# from the rear axle when hooked (no spring bar tension).
  • When using a WDH a portion of the tongue weight will be transferred to the trailer axles. Unhook the bars and it is all on the truck.
    Larry
    Not sure I understand why? If I know my vehicles weight without the trailer (weighed, using cat scales) and then weigh with the trailer, to total weight gain to my TV will be the tounge weight of the trailer, right?
    Larry
  • what do I need to do to calculate the trailer TW?
  • Just get an additional scal reading... Just drop the trailer on the first scale pad (literally un-hitch)... It's simple and quick to do. Then you know for sure.
    This is how I discovered that my pop up had 470 lbs of tongue weight loaded for camping... Reverified with the bathroom scale technique at home.
    The bathroom scale technique works very well. I was within a few lbs of the Cat scale reading.
    Thanks!
    Jeremiah
