Update
I found the issue with my electrical… actually had a buddy of mine help me, I was lost and frustrated. After cross checking things, it turned out that i had issues.
1) Docking lights were shorting out, removed both both OE docking lights to find the driver side burnt and causing short. This was also causing the buzzing/humming sound at the fuse box. Here>>>
so since I had both of the OE light fixtures out, I replaced them with Pro Comps square LED off road lights… Man this thing light up the deck and the back of the rig…
Pretty bad photo of the lights on…
2) issue was the relay or circuit breaker in the bath under the lavatory
Here>>>
the breaker closest to you.
Fixed both of these areas and BAM!!! all is good. Battery is charging, no more buzzing sound. I am a happy camper (no pun intended)
Thanks for everyones input, it really help.
