I have two Renogy mono 100W in parallel and will be adding another 100 watt this weekend. I run these through the stock Renogy PCM charge controller, I think its called Adventurer, or something like that.
I have a three battery bank, each group 24 is an 85ah AGM. One is in the coach battery compartment, the other two I located inside plastic group 24 marine battery boxes, in the wardrobe after beefing up the wardrobe bottom with a 3/4 plywood layer to support the weight of the batteries. I use the temperature sensor in one of the battery boxes.
My charge controller is also in the wardrobe along with my 1000w PSW inverter/charger. I have fused the the PV leads (30 amp) coming into the wardrobe (from the roof) and fused the battery lead from the controller with a 250 amp car stereo fuse holder. I have a Bayrite meter/info display cut into the range hood side of the wardrobe bulkhead, which is convenient for my other indicator lights in the range hood. I used a decora outlet plate as the bezel for the indicator meter. It is a perfect fit.
Believe it or not, I am still able to get the family jackets, etc into the wardrobe. All my solar and electrical junk in there took up about 1/2 the capacity of the wardrobe. And no, DW was not happy about this mod, at least from a storage space consideration, but she sure does love checking her facebook page when we are boondocking.
Two of my panels are on Windy Nation tilt-up mounts, I wanted to be able to take advantage of low West Coast beach sunsets. The third panel is on the stock Renogy mounts, which I dislike for reasons mentioned in other posts, removal of the panels if necessary is problematic (but not impossible).
I found that 200W was not enough in any given day boondocking (highway driving gets a lot more collected energy and fully charges fine) so I am adding the third panel for those long boondocking stays. Since I run the PSW inverter to the outlets in the coach, my family has a tendency to use more than the average power consumption.
