Photomike wrote:
Have you thought of a wood stove? Those little ones for boats are really cool and put out a lot of heat. You could keep your current unit, add a wood stove to heat / dry things out during the day and then use your furnace at night. If you have insulation in your current unit you are not going to get much better with anything else.
I went the van route and I do miss the 4x4 of the truck camper. As much for peace of mind as anything.
Here is info on my units.
Yes, I had certainly considering a mini wood stove for the current truck camper. But in reality, it's an experiment to test the truck camper combination out. After a couple issues with it, I drew the line and said no more money is going to be spent on it.
Ultimately I want a truck camper with all the proper amenities/creature comforts. We do travel a lot in the summer (just started winter), I'd like things to be a little easier/better set up.
