covered_wagon
Dec 31, 2021Explorer
During slight winds or benign blustery weather it is a good time to inspect your trees. You have a hazardous tree is if you see the ground moving with the tree. Means the tree won't stand for long in a stronger wind storm and is loosing anchor to the ground. The bit about too much moisture means when the grond is so saturated it becomes loose ground.
A good tree will bend with the wind and not be moving the ground, has deeper root system.
A tree that is top heavy, grown too rangey as they call it, can break at the main trunk and fall as in an ice storm that builds up too much weight. So if you see a tree with too much bending swinging with a lot of upper story it's time to remove that one also.
