desertroad's avatar
desertroad
Camper batt power not back on after disconnect shore power
Hi All,
I'm puzzled after I disconnected from shore power and the battery power didn't come back on. Several positive connections go directly to the battery such as the radio, kitchen, and lighting. All are out. When the truck is running, the power is also restored only if running. Checked the 3 fuses inline near the battery, all are OK, also the fuses in the fuse panel. Battery is full, and switched out with another battery just to be sure there wasn't some issue with the battery. There is just a BMV712 Victron smart battery monitor, there is continuity through the shunt. Also a disconnect switch, that is turned on and also has continuity. No idea why there is no power coming from the battery. It has to be something simple. I bought this camper used, so perhaps there is a fuse or switch that I'm missing. Any ideas?
Thanks!
