Locatuse's avatar
Locatuse
Camper electrical problem. Help please
I have a 1979 something 30 foot camper.
I have a power pole on my property with two rv hookups and two normal outlets. Gfci
My trailers rv hookup cord is not long enough to reach my power pole so I have a rv to normal outlet plug adapter on the end of my rv hookup cable with a regular extension cord that goes to the power pole.
I have four breakers inside this camper. One is for "general purpose" one is for "air" one is for "appliances" and last one for "lights". And in the middle of them is a "test button" that looks like a breaker that says if I press the test button the unit should trip and disconnect the power. I can press that button all day and nothing will happen to my power in here.
The problem is. Whenever I turn on the appliance breaker, the gfci by the power pole trips and the power to the camper is shut off.
I can have everything on in here minus the appliance breaker. I can have the General purpose. Air and lights breakers all turned to on and everything is working. The only thing not working are any of my outlets. So I can not plug anything in. The moment I take the "appliance" breaker from off position to on position the power shuts off. And nothing gets tripped inside my camper. I have to go out to the power pole and hit the reset button on my gfi and the power will come back on. That is only if I have my "appliance" breaker in the off position. I can have general purpose air and light breakers turned on and it will be fine. If the appliance breaker is in the on position. And I reset the gfi out by my power pole. The gfi by my power pole will shut off - reset- trip itself again
The even weirder thing is. I was in this camper a week ago and everything was fine. I had a heater plugged in and a tv going. For like eight hours. And then the power shut off. And it kept tripping out by my power pole. So I replaced the apliance breaker and tightened some stuff down. And it worked again like whoa easy fix. And about four hours later. Everything shut off and has been tripping out by the gfi power pole ever since.
Please help. Do I have a short in my trailer? A bad "test" breaker? A bad rv to extension cord adapter??? Should I replace my gfci with a normal outlet?
Any ideas? It'd be greatly appreciated before I start following all these wires for a short or fray. Which I have done alittle already and haven't seen anything.
  • Locatuse wrote:
    beemerphile1 wrote:
    Your description is confusing. Is the GFCI tripping or is it a breaker?
    If it is the GFCI tripping then you have a ground fault not a shorted circuit.
    The gfci that has two normal outlets is tripping. It is beneath my breaker panel which nothing is tripping on that....
    You have a ground fault.
    A ground fault occurs when there is an imbalance between the hot and neutral wires. That imbalance is often caused by water intrusion in an exterior receptacle.
    Because the problem is intermittent, that is another sign of a possible water issue. Any outside receptacles on the RV?
  • It could also be that your shore power cord, the adaptor, and the extension cord are operating at a high amperage draw with a less-than-good contact in the mix. As the three items are used the adaptor or part of either cord set are deteriorating and causing the ground fault. With the new adaptor, you may have hit a home run.
    This is where that meter comes in handy, you can hook it into each cord or adaptor and find if continuity is lacking in a piece of the system.
  • This is getting interesting. Please post the fix when you get it figured out.
  • Replace the new GFCI. You'll either have a cheap fix or backup GFCI.
    Then disable each plug one at a time until you figure out the circuit routing and/or the problem. You can give priority to water related plugs: outside plugs, sinks, refer and HW.
    Intermittent problems can take time and patience to find.
