Reddog1
May 17, 2013Explorer II
I have never looked for a backing plate on my 1988 Bigfoot. I do not know if they used backing plates. Actually I replaced my jacks with a Stable Lift. I did leave my factory mounting plates in place. On my Bigfoot, it would major task to get to a backing plate in the rear where the shower is. The other three not so bad.
You should be able to look at the threads on the screws to see if a wood or metal backing plate is used. While it is possible they used no backing plate, I bet they did. The fiberglass at the corners is the thickest, maybe 3/16 to 1/4-inch thick. I question it would hold a screw for the jacks.
On my Bigfoot, the mounting plate wraps under the front corners, with screws under and up the front of the plate. Hard for me to imagine them coming loose. The rears do not wrap.
When you say your screws "keep loosening up", is it all of them or only a couple? Photos might help.
Wayne
Wayne
44,066 PostsLatest Activity: Jul 25, 2018
