Reddog1
May 17, 2013Explorer II
From the photo, it looks like the water on the right side? If so, it looks like you could pull the water heater, and reach the inside. I would use something like a 1/8" drill, and drill through. You then might see if you can in fact use a nut and bolt.
To be honest, I would not be overly concerned. The jack lifts the TC up, and the pressure on those under wing bolts do not carry a load, but only keep the bottom of the bracket from sliding forward. They would do their job if only held in place with masking tape. The bolts in front do a very different job. If it were mu TC, I would use the next size larger lag bolt (not screw). I would only drill the steel part of the jack bracket. I kinda think the existing screws are 3/16, so you could use 1/4" lag screws to replace them. The Lag screw have a hex head, not Phillips as you probably have.
As for the gap, mine has had that since 1988. Never a problem. My guess is someone stripped the screw out trying to close that gap.
Wayne
Wayne
44,066 PostsLatest Activity: Jul 25, 2018
