Bigfeets's avatar
Bigfeets
Camper Jack Backing Plates for Bigfoot
Has anyone installed backing plates on their Bigfoot jacks? I can see that the tiedown points have backing plates but I don't think that the jacks have them. It looks like the jacks are screwed into the camper and mine keep loosening up. This does not look like an easy mod but I sure would sleep better knowing that my jacks are bolted down and not screw into fiberglass. Anyone retrofitted their jack mounts to the camper?
  • I have never looked for a backing plate on my 1988 Bigfoot. I do not know if they used backing plates. Actually I replaced my jacks with a Stable Lift. I did leave my factory mounting plates in place. On my Bigfoot, it would major task to get to a backing plate in the rear where the shower is. The other three not so bad.
    You should be able to look at the threads on the screws to see if a wood or metal backing plate is used. While it is possible they used no backing plate, I bet they did. The fiberglass at the corners is the thickest, maybe 3/16 to 1/4-inch thick. I question it would hold a screw for the jacks.
    On my Bigfoot, the mounting plate wraps under the front corners, with screws under and up the front of the plate. Hard for me to imagine them coming loose. The rears do not wrap.
    When you say your screws "keep loosening up", is it all of them or only a couple? Photos might help.
    Wayne
