prujak
Aug 30, 2013Explorer
Camper Leveler
I saw these a couple months ago. After our last trip with trying to get wood planks under the one side to get the TT level I searched and found these easy to use trailer levelers. I contacted Anderson...
Bumpyroad wrote:
I think you should cut the leading edges at a 45 degree cut, and 1 1/2 (2x8/10) would be sufficient. 3/4 is being too extreme. just be sure you use boards that are wide enough to support the sidewalls of your tires.
bumpy
