garryk6 wrote:
Not being familiar with your sunlite, does it have a Hot water heater? If you are not too afraid of freezing issues, install an external shower, and spend $60-100 for a shower tent that is free standing, use a wooden shower floor. If you do not have a hot water heater, the portable external hot water heaters could be plumbed in for use outside from your TCs water supply. This may not work if there are rules about not allowing water on the ground... I have a similar predicament, as my wife would appreciate the ability to shower in our TC. I hope to weld up a shower pan in aluminum plate. And add a Hotwater heater. But I need to weld up a second 14 gallon gray water tank first...
Too many projects, so we continue to either find facilities, or bird bath it between shower facilities..
Garry
Just joking but asking about a Hot water heater is good for a chuckle as I have just a water heater since hot water does not need to be heated:)
