sgrizzle's avatar
sgrizzle
camper tire pressures
I have a Keystone Laredo (29 BHS, w/slide)
tires say 65 max PSI...do I put the max in or a few less? When I bought it, I noticed it had 50 psi in them. I currently have 58 psi in them.
We are getting ready to head to Yellowstone next week and I want to be sure I have the right PSI in them.
Thanks!
  • ktmrfs's avatar
    ktmrfs
    Explorer III
    Thanks!
    the side of the trailer should have a sticker that has the tire pressure listed. Folow it. In most cases it will be the max pressure for the tire load rating that came with the trailer.
    if not most ST (trailer) tire mfg recomend running at the max inflation pressure regardless of load. That is the way they are designed.
    Others go by tire load vs. pressure charts. I don't, I just run them at max pressure, they still wear fine and even and last 25-30K miles.
