IDoMyOwnStunts
Dec 29, 2015Explorer
I have the same year and make of truck as you, except mine is the Ecoboost. If you don't have the max tow package on your truck, you are likely going to exceed your receiver weight of 1050 lbs once you have 2 full propane bottles, batteries, and the added weight of of the weight distribution hitch. If you have P rated tires, you will feel like you're towing on marshmallows even at the max of 44 psi on the sidewalls. Trust me on that. I've done a lot to make my towing experience better. I don't lack for power. But if I had to do it all again, I would've rather saved the money and bought something lighter. Good luck!
44,071 PostsLatest Activity: Aug 16, 2026
