cyonn's avatar
cyonn
Can I pull this trailer with my Suburban?
Hello All!
I have a 2016 Chevy Suburban LT 1500 with the Max Trailering Package. Stats:
5.3L V8 355HP@5600, 383 Torque @4100
Axle Ratio: 3.42, Wheelbase 130"
GCWR: 14,000
Max Trailer Weight: 8,300
Max Tongue Weight: 1,000
GVWR: 7,300
Payload Max: 1,682
GAWR Front: 3,500
GAWR Rear: 4,200
GAWR total: 7,700
Curb Weight: 5,586
When using a weight carrying hitch:
Max Trailer Weight: 5000
Max Tongue Weight: 600
Anything above what is above requires a WDH
I'm looking at a 2016 Starcraft Travelstar EXP 207RB
Unloaded vehicle weight: 3,962
Dry Hitch Weight: 405
GVWR: 4,950
Cargo Capacity: 988
Exterior Length: 22' 9"
When I do all the calculations, including cargo and my passengers, the trailer seems to be OK and under all ratings for the Sub by a safe margin. Even using a rule of "Every 1 foot of trailer = 5" of wheelbase" is under the 130" the Sub has.
I feel really comfortable that my Sub can pull this trailer, but when I read all the opinions on the forums, I get everything from "I wouldn't pull anything with a 1/2 ton Sub - see this picture (shows picture of a rolled over rig)" to "I've pulled my 28' trailer great for 20 years!"
Its a bit confusing, so at that risk of being even more confused with opinions - can someone check my math? Everything looks ok to me and it seems as long as I equip the hitch properly and drive safely it should be fine. Anyone with experience pulling a 23' 4,000# TT with a 1500 sub with the trailering package?
  • Your are beyond good with this combo. I pulled a 25' trailer that was 4600# empty, with two different Tahoes and a Suburban. In total I had to have been near, or even over, 100K tow miles and had ZERO issues with any of the Chevies. Have fun.
  • I currently have an 18' pop up that ill be trading in. Picking up the TT on Monday and will be going to a local state park here in TX the next weekend!
  • When are you going to pick up new trailer and where will your first trip be???
    :B
    GO and ENJOY!
  • Yep - tow package and integrated brake controller.
  • Good grief yes, you are fine.
    Some people wouldn't pull a utility trailer with anything less than a 3500. They are whacko.
    I would recommend sway control and weight distribution. The numbers may be OK without the weight distribution, but I guarantee it will handle and ride better with it. And IMHO very few RV trailers should be towed without sway control.
  • My only question does the Sub have a tow package and Brake controler? Trailer weight seems ok.
