Gdetrailer
Apr 01, 2016Explorer III
Undercover Poe wrote:
Since I'm asking the question, I think I know the answer (it's probably no) but let's run thru the match and see how much over I am and how big of a deal is it to be over. Here is my stats on my trailer
I'm trying to do this with a 2007 3500lbs tow capacity ford explorer, 2" aftermarket hitch is installed as well as 7 pin and brake controller.
Umm.. No, not gonna happen.
The unladen weight alone IS already 100 lbs OVER your "tow rating", not to mention if you add in propane and water as they did on the sticker you are now at 3,948 lbs..
Then add in your food, drinks, clothing, pots and pans, bedding and any other items you are WAY over your 3,500 lbs..
And that is totally ignoring your CARGO/PAYLOAD that may be available for your vehicle (which I can assure you that you ARE WAY, WAY over).
You need to ignore the supposed 3,500 lb tow rating and find out your vehicles cargo rating.
Newer vehicles have a big yellow sticker on the drivers door post which will clearly state the cargo rating.
If you don't have that you need to find the vehicles unladen weight and the vehicles GVWR.
Subtract the unladen weight from the GVWR and the result is cargo weight.
Then subtract the driver and passengers weight, FULL tank of fuel and any other items you put into your vehicle.
The left over result is the max tongue weight your vehicle can handle.
Once you find the remaining cargo weight you divide that by .15 (which is 15% tongue weight) and the result is the absolute max towing weight you can have without going over the cargo weight of the vehicle (tongue weight becomes "cargo" to the vehicle).
Example, say you have 200 lbs of left over cargo for the vehicle..
Divide 200 by .15 and you get 1,333 lbs as you MAX amount you can tow..
Typically when they give a 3500 lb tow rating they are assuming tongue max of 350 lbs.. 350 dived by .15 is 2,333 lbs.
So really that supposed 3,500 lb tow rating is out the door..
When ever I see a vehicle with a 3,500 tow rating a know it was not put there to pull a heavy trailer.. It was put there to allow you to pull small light trailers..
Sorry to burst your bubble, but you NEED to find a trailer the weights HALF the unladen weight of this one but to be certain you NEED to find or calculate the max cargo of your vehicle after deducting anything you put into the vehicle.
44,055 PostsLatest Activity: Dec 23, 2025
