JIMNLIN
Jan 15, 2014Explorer III
Thanks for giving us the trucks actual front and rear axle weights.
Your F350 DRW has a 8250 RAWR for carrying loads in the bed. Most TCs add little if any weight to the trucks front axle so its not a worry.
Your trucks rear axle weighs 3160 lbs which leaves around 5000 lbs for a max payload. I don't know how much the TC your looking at will weigh so you do your own math.
Some folks use the trucks GVWR to determine a payload. Its safe also.
I wouldn't add a thing till the TC is loaded. Then is the time to make a decision if any suspension help is needed on those big 8250 lb RAWRs and four tires.
44,066 PostsLatest Activity: Mar 14, 2015
