Bedlam
Jan 15, 2014Moderator
The Dana/Spicer 80 rear axle under your truck was designed for an 11,000 lb rating. It is up to you if you want upgrade other components in the rear of this truck to accept more weight. I suspect that the Lance TC on the rear of your truck plus trailer hitch weight will put you around 9000 lbs on the rear axle.
44,066 PostsLatest Activity: Mar 14, 2015
