Bedlam
Jan 15, 2014Moderator
With a DRW setup, tires usually are not the weight limitation. However, better tires with stiffer sidewalls may make handling better at higher weights.
The suspension is probably designed for the softest ride while carrying the maximum load on your door placard. You will want something that either props up the current suspension or adds to it. At the same time, you may find stock shock dampening is insufficient and heavier dampened shocks will help ride quality.
44,066 PostsLatest Activity: Mar 14, 2015
