- LynnmorExplorer IIHere is the information:
http://www.bandbmolders.com/pdf/B_BCatalog_WaterSection.pdf
Vacuum break
Enlarge it so you can read it. - BumpyroadExplorermy old fashioned one leaks all the time when shut off, its an air break or some such of arrangement. lets me know it is working properly. I certainly wouldn't want that type inside.
bumpy - ScottGNomadMine is 11 y/o and has never leaked but it's all brass. Maybe that makes a difference.
- BumpyroadExplorer
Lynnmor wrote:
They will leak, says so right on the manufacturers website. They are not to be installed where water damage can occur. I took mine out, there is a check valve in the inlet so it ain't needed. Toss it.
yep, my tank flushers worked just fine with out the inside one.
bumpy - LynnmorExplorer IIThey will leak, says so right on the manufacturers website. They are not to be installed where water damage can occur. I took mine out, there is a check valve in the inlet so it ain't needed. Toss it.
- Heavy_Metal_DocExplorerTest your black tank flusher and watch that valve. Ours is in the bathroom cabinet under the sink and was exactly that same black type. It leaked the first time I used the black tank flush and put water all over the floor. It got replaced under warranty with a clear plastic version that seems a little better quality.
I work with enough plumbing to understand what it was as soon as it leaked and really got a laugh out of the dealers reaction when I told them what happened. I got the canned answer "We're not sure what's going on....We've never seen that before!" LOL....really?.... - ScottGNomad
PeteK-Hou wrote:
ScottG wrote:
It's a back flow preventer for the black tank flush out system
Thanks. My previous camper did not have that feature.
I appreciate the info
-pete
Your welcome.
Just another thing to winterized ;) - PeteK-HouExplorer
-pete - ScottGNomadIt's a back flow preventer for the black tank flush out system
