d3500ram
Mar 11, 2018Explorer III
Just making sure of your intent... it should not be a problem.
Obviously, you will need a camper with no saddle wings mounted to the camper and no back panel either. I do not know of newer campers without a back light panel of sorts (perhaps there are some)... but there are older ones out there that could work.
Your front tie downs will be for a normal camper, but the rear ones will need to be elongated or extended somehow. My set-up for ties downs is the reverse- my front ones are elongated with chains.
Do you have the truck yet? ...did not see one listed in your profile, if not, I would recommend at least a 250/ 2500 series minimum.
44,064 PostsLatest Activity: Apr 11, 2026
