roam1
Jul 12, 2013Explorer
fourwinns6 wrote:
Roam1 what is a cyphon breaker sp?
I drilled a small hole in the bottom of the top of the loop, if that makes sense, that way when you fill the tank and it goes up and over the loop, when it cyphons, the small hole in the overflow loop will break the cyphon
So when you fill the tank and it fills the overflow hose, a bit will leak out but not much, but when the cyphon starts, the small hole you drilled will break the cyphon
44,066 PostsLatest Activity: Apr 10, 2026
