- jefe_4x4ExplorerIt seems new security measures went in 3 days ago on the 17th. I've trashed both Woodalls and RV.net portals from my menu. Even Trailer Life and Good Sam are presenting a few hoops for you. One go-round reminded me of "Groundhog Day" with jefe chasing his tail, round and round and getting the same result.
jefe - whazooExplorerJefe, you need to Put your right foot in, take your right foot out. Put your right foot in and shake it all about. Do the Hokey Pokey and that's what it's all about.
Well it sounded funny at the time, in my brain. - Reddog1Explorer IIWhen RV.NET goes nuts, I just use Goodsam.
Wayne - jefe_4x4ExplorerO.K. I think I have located the problem. I'll go back and re-upload all the pics to fit the text with the correct URL. Trailer Life seems to be more receptive than Woodalls or RV.net.
I have also started to log out and log back in each time. Time consuming, but effective.
jefe - jefe_4x4Explorer
- jefe_4x4ExplorerBopp,
Yes, every pic has many "%" noting that it has a file name Death Valley. What if I drop the extras from photobucket for the URL? It's always worked before. I'll go to Trailer Life or GoodSam's portal.
jefe - profdant139Explorer IIDutchmen, that is a great tip about logging out in order to get around the robot blockage. I will try that later today. Thanks!
- DutchmenSportExplorerI've been using the GoodSam portal, and been logging out after every session I use. When I came back, I have to enter my user ID and password again. I started doing this because I was getting the "I am not a robot" page, which I could never successfully get past. Found out by logging out, shutting down the browser and taking the time to log back in the next time has taken care of this (for a while anyway). I had a previous post for this problem, so either I've found a good work around, or it's been fixed, because I've not encountered it for a few days now.
I work in IT, I'm a software tester, and it's not uncommon at all for the developers to fix a problem "over here" and it breaks something "over there". So, who knows what's going on.
I suggest using GoodSam.com, select the tab "community", in the drop down, select "Forums" and your in. Log out after each session. Shut your browser (occasionally clear your cookies and cashe) and see if that helps.
Good luck. - kohldadExplorer III
Not gone. Just the link from Woodalls is. Here's your Teton TR: http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/28980662.cfm
Thanks, this will help fix the TR sticky for a number of links. - RoyBExplorer IIThe only portals I use here to get on the RV NET Forum is GOOD SAM or TRAILERLIFE... I do not have much success anymore just using the main RV NET portal...
Someone was testing last week trying to send a lot of large photos. Didn't read about what he was trying to do but he was apparently getting cut off if he had many large photos to post...
Roy Ken
44,052 PostsLatest Activity: Oct 29, 2025
