Dadoffourgirls's avatar
Nov 10, 2015
Canyon Diesel MPG - 22 city 31 hwy 25 combined
DETROIT – With efficiency that complements its leading capability, the all-new 2016 GMC Canyon diesel is rated at a segment-topping 22 mpg in the city and 31 mpg on the highway in two-wheel drive – or 25 mpg combined – according the U.S Environmental Protection Agency.
Canyon diesel four-wheel drive models are rated at 20 city and 29 highway – and 23 mpg combined.
In addition to the fuel economy ratings, the EPA has issued a “Certificate of Conformity” for the GMC Canyon diesel. The agency expressed no issues or concerns following its recent, extensive testing and evaluation of the emission control system on the Canyon diesel.
“GMC Canyon is designed for those who want a smart-sized premium pickup that is quiet, capable and efficient and the new Duramax diesel engine gives customers another choice for handling heavier work and recreational needs – while doing it efficiently,” said Duncan Aldred, vice president of GMC Sales and Marketing. “It’s the very definition of GMC’s professional grade ethos.”
The Canyon diesel’s fuel economy is not only segment-best, it tops all full-size truck mileage ratings while offering a higher trailering rating than all 2015 Ram 1500 V-6 models and some 5.7L V-8 models, as well as the 2015 Ford F-150 equipped with the 3.5L naturally aspirated V-6 – and even the 2015 Nissan Titan S model with the 5.6L V-8.
The diesel’s efficiency also means it can go farther between fill-ups. With its 21-gallon fuel tank, it offers an estimated highway-driving range of up to 651 miles.
Duramax details
Canyon’s all-new 2.8L Duramax turbo-diesel engine generates 181 horsepower (135 kW) and 369 lb-ft of torque (500 Nm) to enable trailering ratings of 7,700 pounds (3,492 kg) on 2WD models and 7,600 pounds (3,447 kg) for 4WD models – ratings unmatched by other midsize competitors.
The Duramax 2.8L has been certified to the cleanest standards of any diesel truck ever produced by GM and meets tough U.S. emissions standards largely with a cooled exhaust gas recirculation system. It is also B20-capable.
Additionally, a variable-geometry turbocharger helps optimize power and efficiency across the rpm band and a balance shaft contributes to smoothness.
The engine is paired with the Hydra-Matic 6L50 six-speed automatic transmission, which uses a unique Centrifugal Pendulum Vibration Absorber in the torque converter to reduce powertrain noise and vibration.
Canyon diesel models also feature a diesel exhaust brake and an integrated trailer brake controller. The exhaust brake enhances vehicle control and can reduce brake wear. It uses engine compression to slow the truck down, reducing the amount of conventional braking needed while traveling downhill. The integrated trailer brake controller system works with the anti-lock brake system to provide immediate and measured brake force, signaling to the electric-controlled trailer brake systems so there is no need for an aftermarket trailer brake controller.
Additionally, models equipped with 4WD feature a new, electronically controlled two-speed transfer case. A 3.42 rear axle ratio and four-wheel disc brakes with Duralife™ brake rotors are standard on all models.
The Canyon diesel goes on sale this fall, offered on SLE and SLT Crew Cab models. It is priced $3,730 more than a comparably equipped V-6 model. Diesel models will require the available trailering package, which includes a hitch receiver and seven-pin connector, as well as the segment-exclusive automatic locking rear differential.
  • Granted, the Canyon diesel may be too much of a compromise for many on RV.NET. But, for the average buyer out there (to include many small businesses), the Canyon diesel could potentially be a double or triple, if not a home-run.
    Gonna be interesting to see how much the Canyon eats into Taco sales.
    The Taco V6 2WD gasser has an EPA rating of 19/24. The Taco 4-banger, 19/23. The Canyon diesel, 22/31.
    The Taco V6 has 278 HP and 265 lb. ft. of torque. The Canyon diesel, 181 HP, 369 lb. ft. For those contemplating a 5000 lb. tow, I believe the Canyon diesel would provide a much more civilized, economical tow experience vs. the Taco V6.
    Time will tell.
  • donn0128 wrote:
    About the same as the Ram 1500 Ecodiesel huh?
    RAM Ecodiesel I thought garnered 240 hp/420 lb/feet of torque while getting similar mileage. 25 combined.
    I'm just waiting for a diesel hybrid truck, lol.
  • I'm not a fan of the styling on these trucks, but they'll probably be a great match for a lot of people who don't need a full size or heavy duty model. I guess I would have figured on a little better than 23 combined but the highway mileage is pretty good at 29.
