Baja_Man's avatar
Baja_Man
Cargo/Bed Slides......which one?
Looking at these for my 2003 F350 short bed.
I tow a TT and want to add secure, easily accessible storage for my trips.
Put a Pro Tops level shell on my truck and now want to add one of these for ease of accessing my generators, ice chests, inflatable raft, fishing gear, firewood, etc.
Both are About $1100 shipped.
1000# Capacity
They are similar but do have some differences....6 bearings (CG) vs 4 (BS); plywood deck (CG) vs some sort of composite foam (BS); metal ring hooks (CG) vs plastic (BS)
Was hoping someone here owns one of them and can share there experiences.
Also, if you decided on one over the other what were the reasons.
Thanks!
  • I have a Joey bed slide in my work truck. I would probably not get another one of that brand but it was purchased several years before I got the truck. I think the more bearings the better as this one gets caught easily. It is also missing a handle to pull it open which is a real pain. I would look for one that has a grab handle across the back. The other disadvantage to any of them is that you can’t store soft or loose material around the wheel wells because it gets caught in the rollers.
  • Hi Pat--
    Are you referring to the grab handle/step on tail gates of newer Super Dutys? Yes, Mine is a 2010.
    NOTE: My 2003 does not have those NICE features!
    1. Did you consider the CargoSlide? Did not know that company existed.
    2. Have you gotten close to the 1000# rating to see how it holds up and slides with that weight?
    Have never tried to weigh. I do keep heavier on the front end.
    3. What is the flat bed made of? Steel They state "Weatherdeck composite" which internet tells me is a foam type of board. Some kind of hard board covered with thin carpet.
    4. Are you long bed or short? Long bed. If short, much can you fit in your bed slide? My long bed is rated for 1200 lbs. I use plastic tubs with lids when possible and stack two high.
    Thanks!
    Pat
  • Hi Pat--
    3. What is the flat bed made of? They state "Weatherdeck composite" which internet tells me is a foam type of board.
    4. Are you long bed or short? If short, much can you fit in your bed slide?
    Thanks!
  • I've had the Bed slide for about 7 years.
    Happy with it.
    My pickup had the flip up handle built into the tailgate.
    The slide would not clear it.
    Had to remove it and get a flat plate/cover to replace (they make them to fit.
    Pat
