- Need-A-VacationExplorerMark,
As I mentioned, there is a 215/75/14 that has just a little higher weight rating if that will help much.
Good luck! - MKirklandExplorerThanks everyone for your input. Apparently, some of the info I received from Discount tire over the phone wasn't exactly right. I will have to be on guard when I finally do get new tires. At this point, I'm still shopping. Mark
- Boxer_LoversExplorerPut a set of 16" Carlisle's on last year replacing the OEM Towmax that had failed.
About 3,000 miles with no problems. - JIMNLINExplorer III
What model are they? I didn't know Carlisle had an E rated 14" tire.
Yeah Carlisle website shows 5 different lines of ST tires but doesn't show a ST205/75-14 E load range in any of those lines ...even the new Carlisle RH.
If I was the OP I would look close at what Discount tire wants to sell. I've delt with them before on my equipment trailers but no more. My wife knows more about tires than they did. - Need-A-VacationExplorer
bhall wrote:
Need-A-Vacation wrote:
I spoke w/ Carlisle. The 15" RH Radials were indeed rated at 87mph, but due to our govt placing a tariff of 15" tires rated at 87mph they have been lowered to an 81mph speed rating. 16" are rated for 75mph, I think he said the 14" were 87mph but not sure if the rating was lowered like the 15" tires due to the tariff.
I have almost 3k miles on my set that I purchased and installed in late February of this year. I do not go over 65 and wouldn't recommend just by what they post on their website.
http://www.carlisletransportationproducts.com/about-us/faq
"How fast can I travel on Carlisle trailer tires?"
In the past, most trailer tires were rated at 62 or 65 mph. Today, some of our tires are "rated" (speed symbols) at 87 mph (N), some at 75 mph (L), some at 65 mph (J: ST tires) and some at 62 mph (J: non-metric tires).
Please remember that speed ratings are test speeds and not recommended driving speeds. The ratings apply only to the tire itself, and not a particular vehicle. The speed rating does not mean that the vehicle can be safely operated at the tire's rated speed.
We recommend driving no more than 60 mph when towing a trailer.Please always drive at a safe speed and abide by the posted speed limit.
Glad to hear you are happy with the Carlisles so far. While I didn't have that many miles on either set I had when we sold the trailer, I was happy as well. They needed very little air when it was trip time, even after sitting all winter.
As for the speed rating, to me it is peace of mind. The same as running an D rated tire in place of a C, or an E rated in place of a D, due to the extra "reserve capacity" or "reserve speed rating". This is the main reason I plan on replacing our stock tires in the Spring stepping up to E rated tires for the higher weight rating. But knowing I also have a reserve in the speed rating, priceless! Lol Sorry, couldn't resist!
I usually tow at about 65- maybe 68ish, but at times when passing someone due to traffic coming up behind, or on a downhill speed may creep up a little more.
I am sure a lot of the suggested speed is the lawyers covering the company's behind. I could see it now: the "crazy driver" - "Well..... Carlisle stated the tires are rated for "xx speed", not sure why I lost control of my 8k lb trailer....."
Just because your truck can tow at 80mph or so because you have the power, can you control it?
Safe travels everyone!!! - richy2Explorer IIAfter experiencing a failure with one of my highly touted Maxxis tires, I found some interesting information on the Discount Tire website. Trailer tires have a mileage expectancy of 5 to 12 thousand miles. Tires should be replaced after 3 to 4 years.
I have about 15 thousand miles on the Maxxis in three years. I rarely drive over 60 mph, yet have had issues with every brand of tire I have had on my trailers.
The latest problem was not discovered until I pulled into campground and noticed a section of tread missing and steel belt exposed. The fact that the tire held together maybe says something about Maxxis. Looking back, I probably drove about 80 miles after hearing a pop which I attributed to something other than a tire. - campiglooExplorerI run the 15" RH on mine. Right at 10,000#, put on about 2 years ago and @ 20,000 miles. Good tire. Very even tread wear and holds air well. Haven't put more than 2-3 lbs air at one time. No blow outs, no leaks, no tread separation.
- AtleeExplorer IIHave no personal experience with the Carlisle. However, I would put a set on my trailer if I needed new tires, and they were the right price.
I still believe the biggest key to getting any TT to last long is to keep them aired up, (don't run them under inflated), don't over load them, and don't run them at higher than rated speed for long distances. - bhallExplorer
We recommend driving no more than 60 mph when towing a trailer.Please always drive at a safe speed and abide by the posted speed limit. - n7bsnExplorerNot enough experience with them yet, I've only put 8 miles on the set I had Discount Tire install today.
But I did a bunch of research and went with them due to the consumer ratings and the speed rating they have.
44,068 PostsLatest Activity: Jun 17, 2026
