Supercharged111 wrote:
Those would be great and are easy to stash, but how are you transferring to the fresh tank? I'm trying to avoid pouring. I suppose it wouldn't be difficult to rig up a pump though.
I just use a live-well pump from walmart, the hose its attached to that connects it to the tank via a hose bib curves downwards, so gravity fills the pump, then I just plug it into the cigarette lighter outlet in the cab over the truck, the live well pump pulls very little power and while its not the fastest pump on the block, it transfers 30 gallons into the onboard tank without too much hassle.
