donn0128 wrote:
bobndot wrote:
Does anyone know the accuracy of the CAT scales?
Probably not ! Unless you are part of the states weights and measures certifiers team that calibrates scales.
Actually the state does not work on scales. They only certify that it is within state mandated specs. Scale technicians would actually work on scales
No, they don't work on the scales. They do
check the calibration of the scales to certify them if they are within the prescribed limits or shut them down until they can be recertified. As they with fuel pumps. It is up to the manager or owner to have the scale or pumps repaired and/or adjusted.
