TerryandKim's avatar
TerryandKim
CAT scales
New too towing. I want to weigh my truck/trailer. The closest CAT scale is 35 min away, there is a govt highway weigh station about 20 min away. I'm next to certain I'm within specs but I also know it's probably close. I'd really like to see what effect the WD hitch has on the axle weights. So, what happens if I weigh at the weigh station and my weights are over the max for my truck? Can/does the scale master stop me from travelling back home? Is there someone that monitors the scales at CAT scales or is that just a scale for the truckers to determine their weights before the hit the highway weigh station??
  • If you go, take three passes.
    Truck alone
    Truck with trailer on ball
    truck with trailer with WDH
    If you find the truck's front axle weight is lower in pass 3 than pass 1, then adjust the WDH to apply more pressure and weigh again.
  • Go to the CAT scale. You will get a printout of individual axle weights. You can adjust things if needed and re-weigh for another $1 or so. Bring in your first scale printout.
  • You can use the CAT scale, anyone who pays can weigh their rigs.
    And as far as the govt scale, they probably would not bother you.
