rjstractor wrote:
Wes Tausend wrote:
and the diesel might even beat the Hemi if:
1) either the gearing matches better,
2) or more likely, the diesel powerband is so wide that gearing match is a lesser concern.
At the risk of further generating this into just another hp vs torque/gas vs diesel debate, I think that the diesel would beat the Hemi towing the same weight by a significant margin for the reasons you listed. Emperical testing bears that out as well. This TFL Test Data page shows that a Cummins beats a 6.4 Hemi up the Ike Gauntlet by more than 5 minutes towing roughly the same weight. We all know that the TFL tests are not perfect laboratory conditions, but those results scream that there's a lot more than peak HP numbers at play when it comes to getting up a hill faster.
It should because the Cummins was making more HP than the Hemi.
