Ryanincc
May 24, 2015Explorer
I am/have always been dead set on not screwing/drilling anything into the ceiling/roof of my Sun Valley. Except for the CO detector, Ive been successful. BUT, when I first got the pup, I wanted to be able to hang shelves. Although pretty cool, Ive never wanted to do the shower/tension rod shelves mod that is popular. What I WAS going to do was use Collapsible Clothing Rods to hang Closet Organizers from, and use 3M Automotive Molding Tape to secure the rods to the roof. With proper surface prep, a few of 3M's tapes will NOT let go. I was, and am still confident it would have worked great, but due to the layout of my pup, and some luck, I was able to use what the Coleman factory had already installed.
Using tarp clips on the door tracks and 24 inch(?) wire shelves, I did this.
And using one of the AC braces, I threaded heavy duty zip ties between the brace and ceiling in order to make loops to hang from.
And hung the organizers
I also used clips that are hooks on other end to hang an organizer for light stuff from the curtain tracks
Hope this helps a little. Im not sure of Forest River's typical pup hardware :@ You can see more pics, details and info here in my photo galleries.
And I know Ive seen someone post a link to buy those stock pantries on the portal or pux. Ill look around and see if I can find it again.
