Ron3rd wrote:
thehippie wrote:
I have 2015 ram 6.7 cummins, after changing the fuel filters i forgot to prime the fuel but i started cranking on the engine right away coz I forgot.
Is that bad?
After realizing I suddenly stopped the engine and primed it turning on off the key like 4 times.
I drove the truck about 3-4 miles and seems fine so far.
No problem. After watching a couple youtube vids, I discovered your experience if pretty normal.
What I do, is change the front filter first. Turn the key on, wait about 5 second. Crank for about 2-3 seconds, won't start, turn key off. Repeat: Same thing happens on the second attempt. Usually starts on the third attempt. Repeat process or rear filter.
BTW, you can get the Genuine Fleetguard (Cummins) Stratopore Filters off Amazon for about $78 for the pair.
The filter under the bed is made by RACOR and is relabeled for MOPAR.
Engine mount filter is made by FleetGuard and relabeled for MOPAR.
You can buy RACOR, FleetGuard and MOPAR as they are all OE.
Don't think the RACOR is available as a FleetGuard.
