cnieto
Jul 15, 2013Explorer
Changing out brake assembly
I discovered upon arriving at my destination that front right hand side tire was squeaking pretty bad. Setup and took tire off and the brakes were rubbing pretty bad. Took off drum and the brake assembly was broken in half from what i can tell. My question is do i need to change just that brake assembly or should i change the left side as well. I tow a 2011 Coachmen Catalina with a 2010 Dodge Ram with the factory installed brake controller.
