vermilye
Aug 23, 2020Explorer II
It depends on the run from your sink to the gray tank. If there is not enough ventilation, a large stream of drain water will siphon out the sink drain trap, letting gray tank gas out the drain. If you can let a large volume of water drain out of the sink without starting a gray tank stink in the sink, you may not need it. In most cases, it is there for a reason...
