rklavoon's avatar
rklavoon
Check Me....I am OK with this set-up
Can you check me (give me your thoughts) on this combination
2015 F-250 Super Duty CC
FX4 Off Road, Camper Package (Extra Rear Leaf Spring)
Payload Capcity is 2,350 pounds
6.2L V8, 6 speed auto
45,000 miles
3.73 ELS
Tow Rating: 12,000 lbs
Proposed Trailer:
2020 Jayco 32BHDS, 2 Slides
UVW: 8200 lbs
CC: 1700 lbs
GVWR: 9,900 lbs
Tongue Weight Empty: 865 lbs
36' long
Reese Strait Line w/Dual Cam Trunion 1,200 Lbs Bars
I currently have a 2014 Jayco 29QBH (6800 lbs dry, 9250 GVWR, 33' long). I don't win any races....I get about 8 mpg (which I am ok with).
I am looking to upgrade to a 6.7L diesel or 7.3L gas (new engine) in 2021.
I am going to be OK with my current set-up for this year if I buy this new trailer?
Thanks for your thoughts!
  • This ^^^
    Looks is just surface or a facade
    A 16 lb sledge looks like an 8 lb sledge...a 12 oz hammer looks like a 16 oz hammer, but there is a huge difference
    Ditto 2 tires from same OEM, same model, same tread, same size...but one is a passenger class and other higher class LT. Very different...costs more, weighs more, better construction, etc
  • BenK wrote:
    This ^^^
    I don’t buy the heavier is better hype at all. Only way to know is to compare them side by side. Lighter doesn’t always mean less or weaker. I have a friend with the exact same layout tt as mine from another manufacturer. We compared them. To start, his is 1100lbs heavier from the factory.
    My lighter tt has heavier rated axles and higher load rated tires. Mine has heavier duty slide gear. Mine has a bigger a/c. Mine has aluminum framing everywhere vs his wood framing. I have solid wood cabinet doors where his are heavy laminated MDF. We both agreed that the quality and fit and finish of mine was better and it’s been aging better too.
