LeBout
Mar 31, 2019Explorer
opnspaces wrote:
Yes, depending on what you're testing for. If you want the batteries state of charge you need to disconnect the shore power cord. But then you should turn on a load like the furnace and let it run for about 2 minutes first to remove the surface charge from the shore power.
Should the reading be taken with the furnace still running or after it has run and is now off?
