- GooddudeokExplorerThx, when I bought the TT they were all four at 45 psi... Ill set them at 50 psi.
- GaryWTExplorerI would run them at 50. Under inflated tires can be trouble. My sidewall says 65 psi and I always run them at 65.
- FrankShoreExplorerDepends what tires you're using, but generally 50 psi is great!
- MudChuckerExplorerId go with sidewall.
50PSI it is. - BB_TXNomadMost people air to the max as indicated on the sidewall. Some tire manufacturers have an air pressure vs loaded weight chart on their web sites. But you must weigh the trailer and know the actual weight on the tires before you can adjust the pressure according to their charts.
- mboppExplorer50 PSI
