RoyJ
Mar 10, 2021Explorer
Groover wrote:
You have made some good observations and are hitting all around some of the answers to your questions without realizing it.
To begin with, a horse trailer doubles the fuel consumption of my 2016 F150. And that is with one that is relatively streamlined. A lot of trailers are not aerodynamic at all. Even those that are are not well matched with the tow vehicle in many cases. When my daughter replaced here bumper pull with a larger and heavier gooseneck trailer her fuel economy went up. I think that it because the gooseneck trailer is much closer to the cab and is better set up to stay in the slipstream of the truck. I can take that same bumper pull trailer and tow it behind my motorhome that is 12ft tall and 102inches wide and it has very little effect on fuel efficiency.
On that note, Tesla knows this well and is great with aerodynamics. Every picture that I have seen with a Tesla tractor pulling a trailer shows a combination that is well matched and equipped for low air drag. No toy haulers with external air conditioners, awnings, door handles, antennas and flat back end will be tolerated.
One of the largest air drags for ICE engines is cooling air. The Tesla semi just won't have that at all. What would have been cooling air will be very aerodynamically routed around the tractor. The power steering, AC compressor and air compressor will only run on demand instead of being driven all of the time. There will not be any fuel sucking exhaust filter regens. There won't be a massive cooling fan sucking 20hp when going up a hill. The oil pump will go away and the cooling pump will be much smaller. My neighbor tells me that 1/3 of his engine hours on his semi comes from idling while stopped. When a Tesla semi is stopped the only systems that will be running are some very efficient operator comfort items and, when needed, some LED lights.
Tesla is also going after rolling resistance by using super singles in place of duals, nearly cutting rolling resistance in half plus reducing air drag. Since the mechanical brakes will only be used very rarely Tesla might find a way a routing cooling air around them except when needed.
All very good points. To be clear, in no way am I not admitting the benefits of electrification, I just don't believe you can make an economically viable long-haul tractor with only 1,000 kWh on-board. As in, if I am an owner-operator, I would not buy that over a $150k Freightliner as of 2021, because the amount of loads I'd have to turn down, the number of routes I'd be restricted to, and the types of trailers I can pull is too limited to make a profit (already very thin).
I will nit-pick a few things: cooling air is not a significant form of drag. Ram's grille shutters save 0.5 mpg (or 2.5%). I've also tested this with full winter grille cover, fuel savings are not even measurable. A/C and air compressors do not run all the time on IC engines. A/C drag is near 0 due to clutch, but the air compressor has a slight draw (<0.25 hp) as only unloader valve is used.
Semi cooling fans actually draw up to 60 hp, so massive gain by the EV. Downside? In cold climates, we must burn battery power to heat the cab, and up here that can be 3kW+ for 24/7 during winter long haul. With I/C, heat is free during driving, and around 90% efficient on Webasto. Re-gen is a big benefit to EVs, but most efficient as weight goes up and hills get steep. On a 3% grade we have very little regen. Here in BC that's a plus, as most grades are >6%.
Again, not saying EVs will never work for long haul, just that as of 2021, I can't see how an owner operator can be profitable with a 1,000 kWh EV tractor. And that's not even taking purchasing cost into account, which will be MUCH higher than a $150k Freightliner. In another 10 yrs, with 2,000 kWh packs, it'll start to become viable for selected hauling operations.
