kw/00 wrote:
...snip....... I lock out 6th and pull in OD 5th in florida all day long. Most hills here no problem with 5th. One in particular I run it in 4th but still keep 65 at 32-3500 rpm. I do have 3:73 gears so the 4:10 option would be better in other states. I have no issues pulling with the 6.0, I love the 6 speed....it keeps the engine in the right power band. When I leave it in 4th the on i75 it has very little speed lose on any hill here. ...snip...Kris
Isn't I-75 in Florida? One place you say you tow all over Florida in fifth, but then on I-75 you talk about leaving it in fourth. I tow all over the country and use fourth, even though it will often hold fifth. About the same performance as I had with my 07 Classic running in 3rd of 4 gears. Most of the advantage is due to the six speed.
